Software-Updates – Suunto Ocean
Genieße den Komfort der kabellosen Software-Updates über die Suunto App, mit denen deine Suunto Ocean immer die neueste und großartigste Software hat.
Versionshinweise
2.51.28
Suunto Ocean  - Release notes: 2.51.28
Update on 12.5.2026
This update brings new features, improvements and bug fixes.
New Dive features:
  • Tide widget
  • Customization of switchwindow and arches for dive modes
  • Dynamic depth graph to dive summary
  • Option to configure a stopwatch to dive views
  • Possibility to link two tank pods to same gas If two tank pods are linked to same gas, the tank pressure field will show two tank pressures during dive
  • Option to set a pressure difference alarm when diving sidemount
  • Support for new dive watch face (available in Suunto app)
  • Water type setting for scuba diving
New Outdoor & sport features:
  • Includes features and improvements from: 2.50.26, 2.48.16, 2.44.52, 2.44.46, 2.43.1
  • Support for pairing multiple sensors of same type. Sensors will need to paired again.
  • Showing sensor information, like battery level and name
  • Downloading maps now enabled also without charger
  • ZoneSense intensity target setting in sport mode
  • Improved Climb guidance user interface and zoom enabled between waypoints
  • Passcode feature for securing the watch when off wrist
  • Support for new watch face types
  • New improved morning report
  • New notification for treadmill calibration
  • Connected sensors can be enabled/disabled per sport mode
  • Sensor services can be selected separately in sport mode
  • New default sport modes for duathlon, swimrun and aquathlon
  • New data fields: Instant, avg and lap NGP, Peak power, Peak pace & speed and ascent/descent to next waypoint
  • ZoneSense adjustable as target to follow in sport mode
  • ZoneSense zone distribution shown in log summary
  • Automatic transitions in triathlon sport mode
  • Automatic transitions in swimrun sport mode
  • Circular transition between sports in predefined multisport modes
  • New map orientation selection for north/heading
  • In-store demo mode for events and demo purposes
Improvements and bug fixes:
  • Localization fixes
  • Snorkelling max depth was missing from summary
  • Algorithm deviation icon not showing on screen after software crash Issues with surface time arch
  • Reduce the time of the no-fly icon
  • Tank pod icon showing in pre-start view even if offline
  • Issues with wifi and maps download
  • Memory optimization
  • Bearing didn’t clear after exiting Scuba dive
  • Adding e-labels for certification
  • Improvement to tank pressure arch
  • Surface time sometimes showing wrong values
  • Transition optimization in menu items
  • Wrong total dive count
  • No message after downloading maps
  • GNSS optimization happens over wireless network automatically every night
  • New winter map styles
  • A wide range of new data fields possible to add in sport mode customization
  • Improved swim style detection in pool swimming
  • Notifications show longer content than before when used with iOS
  • Zoom range indicator on map
  • Improved accuracy with updated GNSS firmware
  • Bike sensor wheel size adjustment added
  • Sleep tracking accuracy improved
  • ZoneSense zone indicator fixed
  • Some crash root causes fixed
  • Button lock problem fixed
  • Battery drain problem fixed
  • Sport mode options remembered better
  • New paired sensors automatically enabled in compatible sport modes
  • Map data field made bigger and more visible
  • Weather data also downloaded over WiFi
  • Improved pool swimming accuracy
  • Smoother transition between menus
  • Improved altimeter stability
  • Improved ascent and descent calculation accuracy
  • Several bug fixes and performance improvements
2.40.56
Gestaffeltes Update ab dem 16. September 2025.
Diese Update enthält neue Funktionen, Verbesserungen und Fehlerbehebungen.
Neue Tauchfunktionen:
  • Option zum Zurücksetzen der Gewebesättigung nach dem Tauchen
Neue Outdoor- und Sportfunktionen:
  • 22 neue Sportarten wurden hinzugefügt. Jetzt können mehr als 100 Sportarten mit der Uhr verfolgt werden: Tiefschneefahren, Biathlon, Calisthenics, Chores, Skilanglauf klassisch, Cyclocross, E-Biking, E-MTB, Feldhockey, Futsal, Handcycling, Meditation, Parkour, Pilates, Skilanglauf im Skating-Stil, Skateboarding, Skibergsteigen, Splitboarding, Bahnlauf, Vertical Running, Rollstuhlsport, Yoga
  • Unterstützung für neue Zifferblatttypen
  • Hinzufügen eines Passcodes, um sensible Daten zu schützen
SuuntoPlus Funktionen:
  • Neue Zifferblätter
  • Mehrere neue Sport-Apps zur Unterstützung der neuen Sportmodi
  • Neue Partner
Verbesserungen und Fehlerbehebungen:
  • Auslösen von Algorithmusabweichungsalarmen nur beim Tauchen
  • Nach Beendigung des Tauchgangs aktive Alarme wurden behoben
  • Zurücksetzen der Tankdruckalarme nur, wenn der Schwellenwert von 1 bar überschritten wird
  • Zurücksetzen der Tankdruckalarme, wenn der Druck steigt Anzeige des nächsten Alarms im Umschaltfenster nach Quittierung
  • Aktualisierung der Flugverbotszeit nach Dekompressionstauchgang auf Maximalwert
  • Problem behoben, bei dem das Tank POD-Symbol weiterhin in der Gerätetauch-Vorbereitungsansicht angezeigt wurde, obwohl der Tank POD nicht mehr mit dem Gas verbunden war
  • Aktualisieren-Taste zur Liste im Tank POD-Menü hinzugefügt, um Tank PODs in der Nähe zu finden
  • Problem, dass die Helligkeitsoption beim Schnorcheln/Tauchen nicht eingeschaltet werden konnte, wurde behoben.
  • Inkonsistente MOD-Werte behoben
  • Kartenoptionen für Freitauchen, Schnorcheln und Mermaiding hinzugefügt
  • Die Genauigkeit der Schwimmdistanz im Pool wurde weiter verbessert
  • Kalibrierung des Laufbands nicht mehr durch Läufe im Freien beeinflusst
  • Probleme bei der täglichen HR- und Schlafaufzeichnung wurden behoben
  • Die Stabilität der WLAN-Verbindung wurde verbessert
  • Zeit bis zum automatischen Start des Tauchgangs verkürzt
  • Schrittzähler-Genauigkeit verbessert
  • Zifferblatt-Einstellungen werden nicht zurückgesetzt, wenn das Zifferblatt im SuuntoPlus Store aktualisiert wird
  • Fehler wurde behoben, der in bestimmten Fällen dazu führte, dass die Schlafaufzeichnung fehlschlug
  • Allgemeine Stabilitätsverbesserungen und Fehlerbehebungen
  • Die Download-Geschwindigkeit von Karten wurde verbessert
  • Verbesserte Logik der Turn-by-Turn-Benachrichtigungen
  • Karten-Display während Pause sichtbar
2.38.42
Das Update wird ab dem 16. Dezember 2024 bereitgestellt.
  • Neue Tauchansicht mit Kompassbogen
  • Möglichkeit, die Peilung auf dem Kompassbogen und im Schaltfeld während des Tauchgangs zu sperren und anzuzeigen
  • Bereitstellung eines Planungswerkzeugs zur Planung von Tauchgängen ohne Dekompression
  • Bereitstellung vordefinierter Konservativismus-Stufen für den Bühlmann-Tauchalgorithmus
  • Neue Option zum Hinzufügen eines benutzerdefinierten Alarms für die Nullzeit
  • Neue Option zum Hinzufügen einer Oberflächeninfo für Freitauchaktivitäten
  • Zifferblätter werden jetzt in den SuuntoPlus Store übernommen
  • Nach dem Update hat die Uhr nur noch ein Zifferblatt und neue Zifferblätter können über den SuuntoPlus Store in der Suunto App zu deiner Uhr hinzugefügt werden
  • Aufstiegsanleitungs-Funktion während der Navigation für Routen mit Höhendaten
  • Möglichkeit, Komplikationen für das Zifferblatt auszuwählen
  • Drei neue Zifferblätter
  • Kumulative Datenfelder als Komplikationen auf dem Zifferblatt
  • Bildschirmsperre im Uhrmodus
  • Datenfeld auf dem Navigationsdisplay
  • Automatische und anpassbare Neuzentrierung der Karte
  • Sportmodus-spezifische Anzeigeeinstellungen
  • Zurückblättern um einen Display im Sportmodus durch langes Drücken der mittleren Taste
  • Neue Benutzeroberfläche für Pause und Training mit der Möglichkeit, Displays zu durchsuchen
  • Schlafqualität im Schlafbericht
  • Unterstützung der vietnamesischen Sprache
  • Möglichkeit, Komplikationen auf dem Zifferblatt zu bearbeiten und auszuwählen
  • Zweite konfigurierbare Verknüpfung
  • Kartenzooming jetzt für bis zu 20 km möglich
  • Fehlerbehebung bei Fällen, in denen die Schlafaufzeichnung und OHR nicht mehr funktionierten
  • Fehlerbehebung bei einem Fall, bei dem die Pool-Schwimmdistanz im Logbuch falsch war
  • Fehlerbehebung bei einem Fall, bei dem der Batterieverbrauch nach der Navigation hoch blieb
  • Bereich zum Starten des Trainings wurde optimiert und schneller gemacht
  • Verbesserte Funktion zur VO2Max-Bestimmung
  • Verschiedene kosmetische Verbesserungen an Menüs und Zifferblättern
  • Einige Korrekturen an der Sprachübersetzung
  • Verbesserte Emoji-Unterstützung mit Farben und mehr Zeichen
  • Verbesserter Schrittzähler zur Vermeidung von Fehldetektion durch allgemeine Handbewegungen
  • Verbesserte Bildschirmhelligkeit im Dauerbetrieb
  • Schnelleres Durchsuchen der UI
  • Neue GNSS- und OHR-Software
  • Fehler behoben, der dazu führte, dass die mobile Synchronisierung fehlschlug
  • Fehlende Freitauchdaten im Freitauch-Widget
  • Unerwartete Abstürze der Uhr
  • GPS-Verbesserungen für die Distanzmessung beim Schnorcheln
  • Falsche Start- und Endzeit bei Start mit Autostart
  • Sensorenliste fehlt im Freitauchmenü
  • Korrekte Anpassung der Oberflächenzeit im Falle einer Synchronisation der Uhr
  • Verbesserungen bei der Kompasskalibrierung
  • Behebung für fehlende Tauchrouten
  • Korrekturen bei Synchronisationsereignissen mit der Suunto App
  • Entfernung des Stopps, wenn der letzte Stopp verpasst wird
  • Korrekturen bei fehlenden Dekostufenwerten
  • Fehlende Nullzeitalarme in der Suunto App
  • Flugverbot wurde fälschlicherweise nach Änderung der Uhr angezeigt
  • Gasverbrauch zeigt falsche Werte
2.36.18
Das Update wird ab dem 5. September 2024 bereitgestellt.
Neue Funktionen:
  • Angabe der Kompassrichtung beim Gerätetauchen
  • Neue Ansicht für den Freitauchmodus zur Auflistung aller Tauchgänge, Tiefe, Tauchzeit und Oberflächenzeiten
  • Der automatische Start für das Gerätetauchen beginnt immer mit dem neuesten Gerätetauchmodus
  • Neue Optionen zur Anpassung des Sicherheitsstopps und der Berechnung der TTS bei Dekompressionstauchgängen
  • Durchschnittswert des Gasverbrauchs in der Tauchgangsübersicht, der aus den Echtzeitwerten während des Tauchgangs berechnet wird
  • Fehler bei der Einstellung der Helligkeit während des Freitauchens behoben
  • UI-Verbesserung in der Gasliste
  • Fehler, der nach einem Firmware-Update eine leere Tauchliste in der Trainingszusammenfassung im Schnorchelmodus verursachte, behoben
  • Verbesserte Berechnungen für Schwimmbecken-, Freiwasser- und Schnorcheldistanzen
  • Fehler bei der Anzeige der falschen Oberflächenzeit im Tauchhistorie-Widget behoben
  • Problem, dass das Symbol für den HF-Gurt nicht angezeigt wurde, wenn OHR im Display vor dem Tauchgang deaktiviert war, behoben
  • Fehler im Zusammenhang mit der Anzeige der Empfehlung zum Gaswechsel beim Abstieg behoben
  • Aktualisierung des Oberflächendrucks auch ohne ausgeübte Wassersportarten, um zu verhindern, dass die Tauchmodi automatisch gestartet werden, wenn der Oberflächendruck fällt
  • Fehler, der die Bestätigung von Alarmen beim Apnoetauchen verhinderte, behoben
  • Alarm bei niedrigem Batteriestand für Apnoetauchen, Mermaiding und Schnorcheln hinzugefügt
  • Bogenverhalten bei Dekompression und Sicherheitsstopps wurde geändert
  • Bereich für die Oberflächenzeitdauer wurde auf Tage erweitert
  • Verhalten des Tauchalarms verbessert, um Situationen mit mehreren gleichzeitigen Tauchalarmen besser bewältigen zu können
  • Zusätzliche Zeit entfernt, die zum Sicherheitsstopp hinzugefügt wurde, wenn während des Tauchens ein schneller Aufstieg erfolgte
