Software updates – Suunto Vertical 2
Enjoy the convenience of over the air software updates via Suunto app so that your Suunto Vertical 2 always has the latest and greatest software.
Aggiornamento software wireless
Quando è disponibile un aggiornamento e il tuo orologio è collegato all'app Suunto, l'aggiornamento software verrà scaricato automaticamente sull'orologio.
Una volta scaricato il software sull'orologio, questo si aggiornerà da solo durante la notte, purché il livello di carica della batteria sia almeno del 20%.
Se vuoi installare l'aggiornamento manualmente prima che l'installazione avvenga automaticamente durante la notte, vai su Impostazioni > Generali e seleziona Aggiornamento software.
Release notes
2.53.42
Staged update starting on April 7th, 2026
This update brings new features and bug fixes
Navigation and maps
- Track back navigation to return to the start along the recorded track
- Offline maps now include contour lines with elevation labels, place names and special location icons
- Climb guidance now supports distance and climb based zooming
- Climb guidance shows section when fully zoomed in
- Customizable bottom "tooth" area with tap to switch data fields across map, climb guidance and navigation displays
- Smart turn-by-turn zooming and notification
- Off-route guidance with distance and direction back to the route
- Improved off-route detection
- New options to manage turn-by-turn and climb guidance notifications
Training and sports
- Recovery heart rate measurement immediately after exercise
- Pool swim drill mode for structured swim training
- Broadcast heart rate to external devices
- Touch screen option available in sport mode
- Use the lap button to control and fine-tune pool swim interval timing
- Auto laps can now be muted during intervals
Daily use and customization
- Support for mixed unit systems
- More flexible notification and sound settings for daily use and sports
- Alarms can be set for specific days of the week
- More responsive altitude updates in daily use
- Sunrise time displayed in morning report
- Number picker now loops
- Indonesian language support
2.50.28
Staged update starting on January 28th 2026
This update brings bug fixes.
Bug fixes:
- Fixed a bug that disabled structured workouts in pool swimming
- Fixed a bug that disabled SuuntoPlus guides in custom made sport modes
2.50.26
Staged update starting on January 7th 2026
This update brings new features, improvements and bug fixes.
New features:
- Connected sensors can be enabled/disabled per sport mode
- Sensor services can be selected separately in sport mode
- New default sport modes for duathlon, swimrun and aquathlon
- New data fields: Instant, avg and lap NGP, Peak power, Peak pace & speed and ascent/descent to next waypoint
- Number of SuuntoPlus apps in sport mode increased from two to three
- ZoneSense adjustable as target to follow in sport mode
- ZoneSense zone distribution shown in log summary
- Automatic transitions in triathlon sport mode
- Automatic transitions in swimrun sport mode
- Circular transition between sports in predefined multisport modes
- New map orientation selection for north/heading
- In-store demo mode for events and demo purposes
Improvements:
- Significantly improved wrist heartrate accuracy
- Sport mode options remembered better
- New paired sensors automatically enabled in compatible sport modes
- Flashlight user interface improved
- Map data field made bigger and more visible
- Weather data also downloaded over WiFi
- Improved pool swimming accuracy
- Smoother transition between menus
- Improved altimeter stability
- Improved ascent and descent calculation accuracy
- Several bug fixes and performance improvements
2.48.16
Aggiornamento in più fasi a partire dal 10 novembre 2025
Questo aggiornamento apporta nuove funzionalità, miglioramenti e correzione di errori.
Nuove funzionalità:
- Tempo di contatto con il terreno e oscillazione verticale nel riepilogo del registro della corsa
- Nuova versione migliorata del report mattutino
- Nuova notifica per la calibrazione del tapis roulant
- Aggiunta la selezione di tutte le app all’elenco dei widget
Miglioramenti e correzioni di errori:
- Il problema del blocco dei pulsanti è stato risolto
- Il problema del consumo della batteria è stato risolto
