Countdown timer
You can use the countdown timer to count down from a preset time to zero. The timer makes a short sound every second during the last 10 seconds and sounds an alarm when zero is reached.
You can show/hide the countdown timer from the start menu under Displays » Countdown. Toggle with .
To set the countdown time:
- Press to until you reach the countdown timer display.
- Press to adjust the countdown time.
- Set the hours and minutes with and . Accept with .
- Press to start the countdown.
You can pause/continue the countdown by pressing
