Suunto Vertical 2 User Guide
- Getting started
Getting started
Starting your Suunto Vertical 2 for the first time is quick and simple.
- Keep the upper button pressed to wake up the watch.
Tap the screen to begin the setup wizard.
Select your language by swiping up or down and tapping on the language.
Follow the wizard to complete initial settings. Swipe up or down to select values. Tap the screen or press the middle button to accept a value and go to the next step.
CAUTION:
Only use the provided charging cable when charging your Suunto Vertical 2.
