Profitez de la commodité des mises à jour logicielles à distance via l’application Suunto afin que votre montre Suunto Ocean dispose toujours du logiciel le plus récent et le plus performant.
Notes de version
2.40.56
Staged update starting on September 16, 2025.
This update brings new features, improvements and bug fixes.
New dive features:
  • Option to reset tissues after dive
New outdoor and sport features:
  • 22 New sports introduced. Now more than 100 sports to track with the watch: Backcountry skiing, Biathlon, Calisthenics, Chores, Classic skiing, Cyclocross, E-Biking, E-MTB, Field hockey, Futsal, Hand cycling, Meditation, Parkour, Pilates, Skate skiing, Skateboarding, Ski mountaineering, Split boarding, Track running, Vertical Running, Wheelchair sport, Yoga
  • Support for new watch face types
  • Add passcode to protect sensitive data
SuuntoPlus features:
  • New watchfaces
  • Multiple new sports apps to support the new sport modes
  • New partners
Improvements and bug fixes:
  • Trigger algorithm deviation alarms only when diving
  • Fixed alarms being active after diving ends
  • Reset tank pressure alarms only when the clearing threshold of 1 bar is exceeded
  • Reset tank pressure alarms when pressure rises Show the next alarm in the switchwindow after acknowledgement
  • Update no-fly time after decompression dive to max value
  • Fixed issue that Tank POD icon still shows in scuba pre-start view after Tank POD is not linked to the gas
  • Add refresh button to list from Tank POD menu to find close-by Tank POD’s
  • Fixed the problem that snorkeling/diving brightness option cannot be turned on
  • Fixed inconsistent MOD values
  • Add map options for freediving, snorkeling and mermaiding
  • Pool swim distance accuracy improved further
  • Treadmill calibration not anymore affected by outdoor runs
  • Daily HR and sleep tracking problems solved
  • WiFi connection stability improved
  • Shorten time for automatic start of dive
  • Step counter accuracy improved
  • Watch face settings are not reset when watch face is updated in SuuntoPlus store
  • Fixed a bug that caused sleep tracking to fail in certain cases
  • General stability improvements and bug fixes
  • Map download speed improved
  • Improved turn-by-turn notification logic
  • Map screen visible during pause
2.38.42
Staged update starting on December 16th 2024.
New dive features:
  • New dive view with a compass arch
  • Possibility to lock and see the bearing on the compass arch and in switchfield while diving
  • Provide a planning tool to plan no decompression dives
  • Give pre-defined conservatism levels for the Bühlmann dive algorith
  • mNew option to add a user defined alarm for NDL time
  • New option to add a Surface notify for freedive activities
  • Watchfaces are now transferred to SuuntoPlus store
  • After the update the watch has only one watch face and new watch faces can be added to your watch from the SuuntoPlus store in Suunto app
  • Climb guidance feature during navigation for routes with elevation data
  • Possibility to select watch face complications
  • Three new watch faces
  • Cumulative data fields as watch face complications
  • Screen lock in watch mode
  • Data field on navigation screen
  • Automatic and customizable map re-center
  • Sport mode specific display settings
  • Browse back one screen in sport mode using long press middle button
  • New pause and exercise end user interface with possibility to browse screens
  • Sleep quality in sleep report
  • Vietnamese language support
  • Possibility modify and select watch face complications
  • Second configurable short cut
  • Map zooming now possible up to 20km
  • Fixed cases where sleep tracking and OHR stopped working
  • Fixed a case where pool swim distance was wrong in logbook
  • Fixed a case where power consumption remained high after navigation
  • Exercise start panel streamlined and made faster
  • Improved capability to determine VO2Max
  • Several cosmetic improvements to menus and watch faces
  • Some language translation corrections
  • Improved Emoji support with colors and more characters
  • Improved step counter to avoid misdetection from general hand movements
  • Improved always-on screen brightness
  • Faster UI browsing
  • New GNSS and OHR software
  • Fixed bug that caused the mobile sync to fail
  • Missing freedive data in freedive widget
  • Un-expected watch crashes
  • GPS improvements for snorkeling distance measurements
  • Wrong start and end time when starting with autostart
  • Sensor list missing in freedive menu
  • Correct surface time adjustments in case of clock sync
  • Compass calibration improvements
  • Fixing missing dive routes
  • Fixes to Suunto app sync events
  • Removing stop done if last stop is missed
  • Fixes to missing ceiling values
  • Missing NDL alarms in Suunto App
  • No-fly was wrongly shown after changing clock
  • Gas consumption showing wrong values
2.36.18
Staged update starting on September 5th 2024.
New features:
  • Provide the compass heading while scuba diving
  • New view for freedive mode to list all dives, depth, dive time and surface times
  • The automatic start for scuba dive will always start with the latest scuba dive mode
  • New options to adjust the safety stop and how TTS is calculated during decompression dives
  • Average gas consumption value in dive summary to be calculated from real-time values during diving
  • Fixed bug for adjusting brightness during freedive
  • UI improvement to the Gas list
  • Fixed bug that caused an empty dive list in the exercise summary in Snorkeling mode after firmware update
  • Improved calculations for pool, open water and snorkelling distances
  • Fixed issue for showing wrong surface time in scuba history widget
  • Fixed issue for not showing HR belt icon if OHR is disabled in dive pre-dive screen
  • Fixed bug related to showing the gas switch recommendation while descending
  • Updated the surface pressure also when not in water sports to prevent dive modes to start automatically if surface pressure drops
  • Fixed bugs related to not being able to confirm alarms while freediving
  • Added low battery alarm for freedive, mermaiding and snorkeling
  • Changed the arch behaviour for decompression and safety stops
  • Increased the range for surface time duration to show days
  • Improved the dive alarm behaviour to better tackle situations with multiple simultaneous dive alarms
  • Removed additional time added to safety stop if fast ascent happened during diving
