- Using 3D compass
Using 3D compass
Suunto Ambit2 S has a 3D compass that allows you to orient yourself in relation to magnetic north. The tilt-compensated compass gives you accurate readings even if the compass is not horizontally level.
The compass is a temporary display that needs to be activated.
To activate the compass:
- Press Start Stop to enter the start menu.
- Scroll to Compass with Start Stop and select with Next.
After 2 minutes in power saving mode the temporary display disappears.
compass mode includes the following information:
- middle row: compass heading in degrees
- bottom row: toggle between the current heading in cardinal (N, S, W, E) and half-cardinal (NE, NW, SE, SW) points, time and empty view with View
The compass will switch itself to power saving mode after one minute. Reactivate it with Start Stop.
For information on using compass during exercise, see Using compass during exercise.
